![Photo](https://bb2.autosport.com/uploads/profile/photo-thumb-3348.jpg?_r=1580703446)
Variable Valve Timing
Posted 01 March 2000 - 03:59
My guess is that they don't, but if asked would say they do if they offer it on their street cars. It's just more pieces to break, and it isn't really necessary with a 7 speed gearbox.
Posted 01 March 2000 - 07:22
You must be right!
Anyway, I would say much the same - not only unnecessary complication, but added weight.
Posted 01 March 2000 - 08:19
Refresh my mind as to what variable valve timing does? Then I will give you my opinion.
Art Nx3L
Posted 01 March 2000 - 12:43
Posted 01 March 2000 - 12:49
Posted 01 March 2000 - 19:39
I understand the theory of what variable length inlet trumpets are for and the advantages they give, but can anyone tell me how they actually physically operate??
"all the time, maximum attack"
Posted 02 March 2000 - 00:34
Art NX3L
Posted 02 March 2000 - 01:19
Art NX3L
Posted 02 March 2000 - 02:27
Posted 02 March 2000 - 03:09
If VVT is used to vary the power band to compensate for load changes? Maybe some of our engine experts could tell us if. We could keep the engine at its max.power rpm 100% of the time electronically we might have the sane results? Other wise the computer knows that the absolute power is at 17,000 rpm and can keep it there. How do we keep the rpm there? With an electronically controled electro hydrolic gear box controled by the same computer.They are using a manuel controled electro hydrolic gear box at the present time.
Art NX3L
Posted 02 March 2000 - 03:26
Art NX3L
Posted 02 March 2000 - 03:49
Art NX3L
Posted 02 March 2000 - 06:37
[This message has been edited by desmo (edited 03-01-2000).]
Posted 02 March 2000 - 07:17
It isn't up to the rigors of f1 anyway? Horse Manuer the only thing we are replacing is Michael's fingers on the shifting paddles with an electronic signal from a computer. The rest of the equipment has been there for years and the computer doesn't get tired after a few laps and varry in its timeing or get rattled after an off road excursion. I didn't intend this to be an automatic gear box it just ended up that way.
Art NX3L
Posted 02 March 2000 - 07:40
Posted 02 March 2000 - 08:18
Art - they still have specific gear ratios - there is no variation once the box is assembled, so they are changing gears. I hate to upset you, old chap, but it just is not a constant variation, but the normal stepping of the gears. Operation by hydraulics, triggered by electronics, that makes no difference. And with a top speed of 220mph, what range must each gear cover? And what rev range does that mean is being used?
The centrifugal timing variation is an enlargement of what happens in the distributor.
Posted 02 March 2000 - 09:22
The Auto Gear Box not being up to the rigors of f1 has nuthing to do with CVT. And Ray did you read my last idea stinks? Read it wont work. And as for the Auto Gear Box it will most definately work. Are we talking about the same thing? And the centrifugal variable system would be no problem and add only a few ounces of weight. Combine both systems and we have the ultimate drive trane. Now give me some detail why it is not.
Art NX3L
Posted 02 March 2000 - 10:32
I wonder if a box with a limited CVT application in each gear would be legal? They'd still be changing gear - maybe put the CVT adaptation between the engine and the box....?
Posted 02 March 2000 - 11:21
What is a CTV? You forgot im I'm from the horse and buggy days.
Art NX3L
Posted 02 March 2000 - 11:22
What is a Cvt? You forgot im I'm from the horse and buggy days.
Art NX3L
Posted 02 March 2000 - 11:37
In F1, automatic transmissions are banned, the driver must trigger the gear change. Even when there is an over rev protection (whioch there is) to prevent a driver changing down while the speed is too high, it can only act by preventing the change taking place, the driver must trigger a second time for the change to take place.
Variable valve timing is used to "broaden" the power band, making the engine more "drivable". At very high revs (15-17K) one presumes that very wild cam timing is needed to get reasonable cylinder filling. SUch wild timing (very large overlap between inlet and exhaust) would make the engine give very low power at low revs. VVT reduces the overlap at lower revs.
Posted 02 March 2000 - 11:44
I looked up CVT and it looks like a glorafied Snow Mobile Clutch.
Art NX3L
Posted 02 March 2000 - 12:05
I Realize that every thing is banned in f1. It'a a wonder that they don't go back to chain drive and wooden spoked wheels. But talking about what could be makes for some nice conversation.
Art NX3L
Posted 02 March 2000 - 14:03
Posted 03 March 2000 - 00:16
Some years ago I built a 185 lb modified Yamaha powered drag sled with a 8200 rpm clutch lockup.So I have a general idea of how the cvt works. There were some pictures of the metal segmented belt on the net. You would have to use a gear reduction box between the crank. and the cvt to greatly reduce rpm. If not centrifugal force would cause the belt to explode. And PDA mentioned that the driver has to trigger the gear change. Unless the rules state that the driver will trigger the shift by hand we have Mad Max by the Balls. If it is by foot on accelerator or hand on paddles the driver is triggering the shift! Do the rules limit the tranny to 7 speeds? If not there has to be a rule that states that the rules can be changed at any time Mad Max decides to.
Art NX3L
Posted 03 March 2000 - 03:54
Posted 03 March 2000 - 07:10
Art NX3L
Posted 03 March 2000 - 08:04
hp-planet.com gets into the Honda CVT with data and a lot of drawings on the unit. This thing is more complicated than a 7 speed gear box. It has a smother transition of power and can hold a constant rpm. But no way can I see it handeling 8 to 9 hundred HP and a set of big slicks. I think my computer controled (semi automatic)gear box would be the only way to go. And lets forget about the rule book for a while.
Art NX3L
Posted 03 March 2000 - 22:47
Posted 04 March 2000 - 01:52
Art NX3L
Posted 04 March 2000 - 09:32
The inovation of the Van Dorne unit is a metal link belt that operated in COMPRESSION versus the traditional snow- mobilie unit with a rubber V-belt operating in tension.
Posted 05 March 2000 - 00:09
In the Honda CVT Van Doorne unit they show a moving version of the hydrolic variable pulley assemblies. As one opens the other closes back and forth. One puts tension on the belt and the other puts compression on the belt. Or due to them both being variable they are always in a compression mode? Due to brain fade with age and the lack of an engineering education maybe you can explane to me how this works? The gear box I am refering to.
Art NX3L
Posted 06 March 2000 - 02:34
DAF invented this type of transmission, DAF was founded by van Doorne, hence the name.
By the way I'm not quite new to the forum, there weren't too many times I could *add* to the discussions, but I enjoy reading this technical stuff very much.
Johan V
Posted 06 March 2000 - 06:59
Posted 08 March 2000 - 13:15
Johan V.
