Was a diesel engine on pole for the 1952 Indy 500 ?
Posted 13 October 2001 - 15:45
And if so, how come, that such an engine was never used again?? (until recently some drivers used VW Golf TDI for rallying) For, if it was fast enough for pole in Indy, who knows; maybe it would be also quick at Monza or Spa...
Posted 13 October 2001 - 16:41
The Cummins Engine Company (based in Columbus, Indiana) fielded a diesel engined car for the first time at Indy in 1931 : it finished a respectable 13th with Dave Evans at the wheel. They came back in 1934 and 1950 with little success. But in 1952 Kurtis designed them a car (nicknamed the $500,000 racing laboratory !). Freddie Agabashian took the pole, but tire problems (probably due to the heavy weight of the car) caused him early pitstops and he finally retired with turbocharger problems (inlet clogged from debris on the track).
In a way, this car brought many changes to Indy. The engine was a heavy truck 6570cc (401ci) in-line 6 and was fitted with a turbocharger, the first in Indy history (400 hp at 4000rpm, 50hp more than a classic Offenhauser). Frank Kurtis' problem was to package his beast. He laid the engine flat on its side with the crankshaft on the left. Then he brought the driveshaft straight back to a quick-change diff offset in the rear axle. The driver sat on the floor next to the driveshaft. And the whole thing was held together with a tubular space frame. As soon as he started building the car, FK saw that it was a good idea. So he built another one for millionaire Howard Keck : The KK500A. The KK roadsters legend was born and it took another wizard of engineering name Colin Chapman to put an end to its supremacy.
Posted 14 October 2001 - 18:39
The 1952 car was a feature of a film (probably commissioned by Cummins) that shows up on the Legends of Motorsport half hour program on Speedvision.
Brian Pratt
Posted 15 October 2001 - 08:24
Alfa Romeo announced that it will run a cup competition whithin the German Touring Car Races in 2002 with identical Alfa 156 with the 1.9 JTD engine! All cars are the same (have to be bought from Alfa with sealed engines, electronics etc.) and it will be - according to the TV report - the first competition with just Diesel-powered cars.
Bert
Posted 15 October 2001 - 16:13
Posted 15 October 2001 - 17:28
Posted 15 October 2001 - 19:27
Turbine and Wankel (rotary) engines were not given any "displacement" or equivalency coefficients in the original issuance of the new Grand Prix -- ah, F1 -- formula in November 1963 -- it was "to be determined" and left at that. When the formula went into effect, the only things I remember was that there was nothing on these except that they had to meet the other mandates of the formula -- weight and safety requirements. I think that for the 1970 revision, there was an equivalency algorithm for rotary engines and another for turbines.
My mind is blank on the Diesels. I don't think the Diesels were left in the final regs, but I do remember that they were mentioned during the drafting of the 1966 regs.
Also, the reason for the turbo failing in 1952 -- debris being sucked into the intake and damaging the vanes, was due to its placement and not any failure of the turbo itself. Had the turbo been placed higher and adequately protected from FOD, it is entirely possible that Eddie Agabashian could have been a serious contender, despite the early tire problems which were in part due to the heavy fuel load and the weight of the engine package.
Even though the Cummins Roadster was not a success, it was to, as mentioned, lead to a whole new generation of Indy cars.
Posted 15 October 2001 - 22:49
Just like the FIATs in the 1923 Grand Prix de l'ACF?
Posted 16 October 2001 - 05:07
Posted 16 October 2001 - 18:20
I don't think there was a Diesel option in the '66 rules; Cimarosti in his very detailed appendix just mentions rotary and turbine engines.
Posted 22 October 2001 - 20:53
Posted 23 October 2001 - 20:36
Posted 25 October 2001 - 08:45
http://www.velocityj...bin/wi.cgi?i=97
Also, the feature film mentioned is titled, "Diesel Race Car". A Cummins promotional film. Outstanding feature.
